04-20-2011 10:49 PM
May try to use a 1000fps cemera to capture the open of the switch, is there any tools to extract the the moving speed of the touch part, thanks.
04-21-2011 04:51 AM
Not as far as I know in Vision Development Module 2010, I think you have to detect the object you're tracking in all you images, calculate the trajectory in pixels and have a calibration to go from pix to length units. You also need to know you acquisition rate of course.
I've measured angular speed of a mechanical watch balance wheel by tracking little objects placed all around the balance wheel in the past, it worked very well.
Hope this helps
Epictetus
04-22-2011 11:29 AM
04-24-2011 09:26 PM
May you give some suggestion how you make it.
Many thanks.
