There are several cameras that can do 1000 fps. Many require reducing the field of view to get the higher frame rate. I would check the Graftek site (www.graftek.com) to see what meets your requirements. Everything they have is LabVIEW compatible. They are also happy to help you if you call and explain what you need.
