Any counter inside 5133
We are trying to use USB DAQ 5133 to collect some pulse waveform.
Beside the single pulse waveform, we also need to record the starting time phase of the pulse according to a 50Hz time reference.
Originally, we do like below
- CH1, random single pulse input, record pulse waveform, trigger by voltage level.
- CH2  a standard reference 50Hz waveform as attached.
-When triggered by CH1, it will record data for both channel. From CH2, we can get the amplitude value, then we can convert it to the phase time as the drawing.
Now we want to improve the system,  can we use the PF1 for trigger and somehow use a counter in 5133 to count the pulse's arriving time, then CH2 will be saved. We do not want to collect every 20ms data, since 5133 transfer back slowly through USB and may not be able to collect 20ms cycles continouesly.
Any suggestion?
(3,429 Views)
I think you can use a "62" series.
(3,415 Views)
The 5133 has 100M sampling rate. It can record sharp pulse shape. Also the USB is easy to integrate. That is why we really want to use 5133.
(3,403 Views)
turbot wrote:
... ... can we use the PF1 for trigger and somehow use a counter in 5133 to count the pulse's arriving time... ...
Any suggestion?
According to the datasheet of the 5133 there's no counter in that device Smiley Sad
So... ...Smiley Surprised
Why do you want/need to improve the system? Do you miss some pulses or what?
(3,396 Views)
Becasue now the time reference ocuppy 1CH, actually 2 channels for data collecting at same time is needed.
If I can use the PF1 for trigger and use some counter inside, then I can use the both 2 channels for data collection.
(3,370 Views)
