Announcing the LabVIEW 2011 Platform beta
hello Lisa,
In few words could you tell us what will be new with this release ?
regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 11 of 19
(5,297 Views)
@tinnitus wrote:
hello Lisa,
regards
Tinnitus
Beta information is available to registered beta testers either via the beta forums or email with the beta coordinator.
Although, I don't think I telling tales out of school to suggest this link will have some updates eventually.
Beta information is under NDA.  Don't talk about the beta contents - its bad juju
"Should be" isn't "Is" -Jay
Message 12 of 19
(5,282 Views)
And there is also this link. Unfortunately the ideas in development do not say which version is the target.
LabVIEW 2012
Message 13 of 19
(5,262 Views)
The correct setting for IE8 is UNINSTALL, If that setting doesn't work, then try making another browser your default. If that doesn't work then manually open another browser. This will eliminate ALL problems with using IE8.
Message 14 of 19
(5,141 Views)
hello i want to know whether the old version labview8.2 programme can be opend in new version labview 2010?
Message 15 of 19
(4,798 Views)
azad deepu, this thread, Announcing the LabVIEW 2011 Platform beta,  is just an announcement of the LabVIEW 2011 BETA tests. It is unlikely that you would get much attention to your question here. The answer is that yes, 8.2 should open in LabVIEW 2010, if all of the required sub-vi's are in directories that LabVIEW 2010 can access. It looks, from your error message that needed sub-vi's are missing, and some of the names in the list are not LabVIEW specific ones (not from National Instruments) but appear to be ones created in the development of the program you are trying to open, therefore would not be installed when LabVIEW is installed.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 16 of 19
(4,790 Views)
no bad juju here. just stopped by to say "i'll give it a whirl" and I hope I can at least figure out where the key goes.........:o)
Message 17 of 19
(4,739 Views)
Hi all,
I just downloaded the file: LV2011_Beta1_32.exe
Can someone confirm this is the LabVIEW 2011 "Platform" beta? I'm interested in Signal Express and I understand it's in this "Platform" package only.
The downloaded filename does not give details as to which package this is and I don't see Signal Express in the Products folder in the list of extracted files.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
Message 18 of 19
(4,302 Views)
If you have a question regarding the beta, please ask it in the LabVIEW Private Beta Forum.  This is a general LabVIEW forum not suited to beta questions.
Lisa
Message 19 of 19
(4,295 Views)
