I am not sure why it is not either. I get the same result. I found this link but the reasons why it does not work (LV Picture not .Net) does not make sense, since you are using the .Net control. http://digital.ni.com/public.nsf/allkb/8D5E7940947C60B486256E92007F46D0
I also found this thread on using it in .Net and way down the page is an interesting topic on why it does not work during long operations using the same thread and I wonder if this couldbe that LV forces this to run in UI thread and thats what is causing the hang up.
http://stackoverflow.com/questions/13485477/can-a-picturebox-show-animated-gif-in-windows-applicatio...
I've played around with this and the animation plays provided that you don't perform another long running operation on the same thread. The moment you perform another long running operation, you'd want to do it in another thread.
The simplest way to do this, is to use the BackgroundWorker component that you can drag onto the form from your toolbox. You'd then put your long running operation code in the DoWork() event of the BackgroundWorker. The final step would be to invoke your code by calling the RunWorkerAsync() method of the BackgroundWorker instance."
Joe.
"NOTHING IS EVER EASY"
