04-10-2018 08:23 AM
Wow amazing another super code. I m trying to build those waveform to be able to be analysed on physical oscilloscope using DAQ to generate the analogue output also I will create a mathematical expression to calculate the area under the curve of the exponential I'm really thankful for your help this is my email send me a message gustavo_dossantos@hotmail.co.uk
I'm sorry I'm not very bright like you I tried to run your code using DAQ and was showing the following error if could have a look will be amazing
thanks lot from London
04-10-2018 10:06 AM - edited 04-10-2018 10:08 AM
As a good starting point (after some tutorials and some DAQmx RTFM 😉 ) is the shipped example
Voltage - Continious Output.vi
(Try to avoid the express vis, they hide too much ...)
replace the the output Array creation for loop with my vi, build a 2D array of dbl from the outputs and change the Anaolg 1d Wfm Nch NSamp to Analog 2D DBL NChan NSamp
PS: Ask the moderator to remove your email from your post.... and you can use the forum to send private messages 😉
(sometimes I answer them .... )
04-10-2018 10:47 AM
This will sound really stupid but I did not understand yours step that you said sorry my brain is really slow
thanks a lot
04-10-2018 12:00 PM
Hi there thanks a lot for your helping and advice I manage to have those signals output
I would like to say thank to everybody that took a look on my project and NI for this space to
help others thank you lot
