05-21-2013 02:46 AM
I am using cRIO 9023 ,NI 9802, NI 9215 and NI 9269 modules, I have acquired an analog input from the module and give it to the Analog output module, the output which I have taken is an audio signal(sound *.wav file) and want to save this output to the SD card module. I am unable to create the wav file in the RT cRIO and that's why I am facing problem in saving the data into the SD card.
I have the followig queries:
How can I convert the output to wav file which I have already acquired from the output module.
How can I save the converted wav file into the SD card module.
If anybody have already worked and have some knowledge kindly share with me.
Ather
05-21-2013 05:55 PM
Here is an example VI that ships with LabVIEW that may help. You can change the Write to Text File to Write to Binary File.
05-22-2013 03:30 PM
I am unable to convert and writ it to the SD card module, it is creating bin file but it is of 1 kB though it must be of larger value because i am using direct analog data from the input module and feeding it to the SD module
