Hello Tilo,
Take a look into the examples shipped with LabVIEW (Help/Find Examples) -> Hardware Input and Output\DAQmx\Analog Measurements\Voltage\. But first make sure you can 'see' the signals in Measurement and Automation Explorer (MAX), through the LabVIEW start dialog with 'Configure...'
Create two tasks in MAX, one for the analog signals and one for the digital signal. You can set these signals directly to temperatur measurements and read them as temperatures in LabVIEW. For fast developing use the DAQmx Expres wizard.
succes,
Ton
Message Edited by TonP on 04-29-2005 03:44 AM
