02-26-2009 01:57 PM
Hello!
I have LV 8.6 installed to my PC with XP OS and my card is 6024E. I've notice that the analog input/output palette is not showing up or missing. I've tried the search but no luck. Traditional NI Daq 7.4.4 is currently installed.
Solved! Go to Solution.
02-26-2009 01:57 PM
02-27-2009 11:12 AM
Here's what I'm looking for as well as the output palette. These shows in the other PC without problem so I don't know what I've missed during my software installation.
02-27-2009 11:14 AM - edited 02-27-2009 11:17 AM
Try reinstalling from the Device Driver CD/DVD and make sure you have Traditional DAQ selected.
You did say that you had NI-DAQ 7.4.4 installed. But if it was done before installing LabVIEW, then LabVIEW won't see it.
02-27-2009 11:32 AM
The drivers was installed after the LV but I'm not aware that Traditional DAQ supposed to be selected during the inatallation.
Thanks for your response.
07-15-2009 12:32 PM
I too don't have an Analog Input/Output Palette but I don't have the option to select "Traditional DAQ." I've looked through the features and cant find it.
Is my version (8.6.1) not have a "Traditional DAQ" option?
07-15-2009 12:34 PM
Check the 4th post of this thread, that fixed my problem.
Goodluck!
07-03-2013 04:19 AM
i am using labview 12.0 on XP OS.even after reinstalling the drivers ,i am not getting the analog input/output palette in the function palette.i am using NI-PCI 6221.
07-03-2013 06:44 AM
Traditional DAQ isn't shipped with LabVIEW 12. I'm not even sure if it is even supported, to be honest. Use DAQmx instead.
07-03-2013 07:52 AM
yup,fixed up the problem.Its DAQmx...
thanks a lot
