I have a problem:
when I´m trying to add the Serial Number, to register LabVIEW, following error message occurs:
"An error occurred on the server. Would you like to try again?Click Yes to retry adding new serial numbers. Click No to discard new serial numbers. If the problem Persists, contact National Instruments technical support at ni.com / support."
I would appreciate your help/advice.
