An error occurred attempting to connect to this compile server
I showed the whole error. FPGA is definitely connected, I guess there is no problem here. All FPGA tools are installed. Vivado Xilinx tools 2017 is installed.
It was causing this problem before, when I uninstalled and reinstalled everything, it was fixed, now there is such a problem. It was working until a few days ago, I don't know why it happened this way.
What is the reason for this error?
I've looked at issues similar to this, but I couldn't find a definitive solution. I can't understand why this and similar errors occur every time.
(911 Views)
What did you do before things stopped working?
I'd restart your computer.
To confirm, you are trying to compile locally.
ALE Consultants
(901 Views)
Accepted by topic author constructionworker
Now after updating all installed files related to FPGA, the problem is solved.
The FPGA compile worker was unable to access the compile file named ''Vivado 2017.2(64)bit''. I have no idea why these files were deleted. Thanks for the answer.
As a result, this is how I solved the problem.
(853 Views)
