11-09-2013 04:21 PM
I am still encountering this problem. I had a trial version of NI software from 2011. It had expired, so I decided to download a new trial version for Labview 2013. For this purpose, I uninstalled the old version and re-installed the new version. I extended its trial period from 7 days to 45 days. After doing this step, I ran into the error that is listed on the message board. One of the message boards suggested to repair NI software. I did this and re-booted the computer according to the instruction in the pop-up message.. However, the same error remains. Now, I found this thread that suggests to repair the NI software a second time. I have started this process, but it takes a long time.
Any ideas on overcoming this situation?
11-09-2013 07:18 PM
Try installing the f2 patch!
http://www.ni.com/download/labview-development-system-2013/4406/en/
11-09-2013 10:05 PM
I just installed this patch and re-booted my computer. However, I am still getting the same error. Any other ideas?
11-09-2013 10:07 PM
Do I need to change some registry setting or file to get the software to point to the right web server?
11-11-2013 12:36 PM
Hi kijijisale,
Since you have tried all the previous troubleshooting steps, let’s see if the service can be manually started.
Navigate to Start >> Control Panel >> Administrative Tools >> Services >> NI System Web Server. Left click the NI System Web Server and in the top of the dialog box click Start. Are you able to manually start the service?
11-11-2013 05:49 PM - edited 11-11-2013 05:50 PM
The server does start. After that, when I tried to launch the examples, I got a different error indicating that Ni Help Server could not be found. Any other ideas?
11-12-2013 06:28 PM
Did you receive the error before extending the LabVIEW 2013 trial from 7 to 45 days?
Also, did you ever receive the error with LabVIEW 2011?
Mike
12-26-2013 06:27 AM
I was looking solution for this problem and I found here. I also encounter this problem when I used this function.some day ago I can used it without any problem, but today the computer jump the window that say"An error occured-The NI System Web Server is not running"
12-26-2013 06:28 AM
thank you very much !
02-22-2014 05:41 AM
there always an easier way to solve problems...
