Although data are same but cannot compare it
Hallo,
I have two outputs in array
1 is from sensor
2 is from data from. txt file
Now the problem is when I read a data from sensor , I need to display it it in  hex. While in hex display column two match with the column two of Txt file but column one didn't. Its hard to explain . I have attached jpg file hope you can help me.
Thanking you
BR
kalu
(2,614 Views)
Hi kalu,
your array2 and array3 do not display the same data even when they look similar!
Using "normal" and "hex" display mode shows yuite different things...
(2,602 Views)
thanks for reply,  but txt file is also the data from sensor and it is combination of hex and ascii .i know i am getting right data which is in array 1  and array 2 but the challange is displaying  it as same as in array 3.
(2,592 Views)
Accepted by kalu
Hi kalu,
"challange is displaying  it as same as in array 3."
Hm, quite challenging, isn't it?
(2,587 Views)
Thanks for your kind support
Everything looks good now the only problem is in array 1 all Bytes are together that mean with out space while in array 2 there is a space after 2 bytes .
BR
kalu
(2,577 Views)
HI
Problem is solve its just because of formate string .
Anyway thanks for support
(2,568 Views)
