Altering Properties of graph palette
I am trying to make only the zoom option on the graph palette visible at the runtime ... !! Is this possible.
Please Help.
Anirudh
Message 1 of 12
(1,302 Views)
Hi Anirudh,
   I think it is not possible to have only zoom option. Only Visibility of
graph palette and selection of active tool in the palatte can be done in run time.
Aarthi
Message 2 of 12
(1,306 Views)
Hi Aarthi,
Thanx for the help . I am new to labview and i am kind of going nuts over this tool.
Thanx again.
Message 3 of 12
(1,305 Views)
You have one indirect and simple Method to do it.. Just select the Graph palette from the visible item category and leaving the Zoom option just make the other options transparent.
Message 4 of 12
(1,304 Views)
Ya that's the good way. i also came to know!!
thanks Anand. Is it possible in runtime??
Aarthi
Message 5 of 12
(1,297 Views)
Hi Anand,
making them transparent ?? how to make them transparent. I am using  LV 7.1 ...... !!
Anirudh
Message 6 of 12
(1,287 Views)
Am not getting the question.. In run time means?
Message 7 of 12
(1,279 Views)
Place the graph indicator in the front panel,select visible items -> graph palatte.
then select set color in tools palette.select transparent[T] for both foreground and background
and click on the place where u want.
Aarthi
Message 8 of 12
(1,278 Views)
Change the colour for graph palette[making transparent] when the vi is running??
just wanted to know.
Aarthi
Message 9 of 12
(1,276 Views)
No you can do these sort of editing while runtime.. If you want to know what are the options that will be available in the run time just Press Ctrl+M then check it. You can change the color of the plots but not the graph indicator.
Message 10 of 12
(1,268 Views)
