Allow programability to few specific bits in a word while other remain fixed
I want to allow user to program 8th,7th and 6th MSB bits of a 16-bit word while other bits in word remain fixed. Let's say for a word "1111111XXX111111" the value of bits represented by X will be decided by what user enters in control.  How to do it?
Message 1 of 14
(2,527 Views)
Accepted by topic author Labbyte
Convert the numbers into arrays and make your replacements there.
Jim
Message 2 of 14
(2,509 Views)
Why the arrays? Embrace Boolean logic! Smiley Wink
Message 3 of 14
(2,493 Views)
Usually boolean operations will be simpler.
If you want to turn on bits, AND them with a constant that has those bits set to 1 and all others set to 0.
If you want to turn off bits, AND them with a constant that has those bits set to 0 and all others set to 1.
If you want to toggle bits, XOR them with a constant that has those bits set to 1 and all others set to 0.
If you need to set them to some arbitrary series of 1's and 0's no matter what the current state of the number is, then use Jcarmody's array manipulation method.  Alternatively, AND those bits with a constant where they are set to 0 (all others set to 1), then AND it with the arbitrary series of bits (and all others set to 0.)
EDIT:  I like Smercurio's manipulations even better.
Message 4 of 14
(2,491 Views)
Hey Smercurio_fc, your way looks quite easy , can you upload vi pls so i can try it...thx
Message 5 of 14
(2,477 Views)
Thx jcarmody, giving me a way out for this.
Message 6 of 14
(2,475 Views)
His is a VI snippet.  Just drag the image from your browser into a block diagram.
Message 7 of 14
(2,473 Views)
That's what I first thought, but it only works one way.
Jim
Message 8 of 14
(2,468 Views)
I went by the original statement of the problem, which had ones. If you want a more generic solution, that's a simple modification (still with no arrays Smiley Wink)
Message 9 of 14
(2,463 Views)
Follow-up:
You can eliminate the 0x00E0 constant by wiring the second input of the top OR to a NOT:
Message 10 of 14
(2,454 Views)
