Allow Rotate 1D Array in SCTL with constant n
Highlighted
If n is constant, it should be a wiring operation and it shouldn't require multiple itterations so it should be allowed in a SCTL.
Message 1 of 8
(1,326 Views)
I just noticed I posted this in the wrong forum. Mods, can you move this to FPGA?
Message 2 of 8
(1,322 Views)
Use the Option link next to your message and Report to Moderator to request that it be moved.
I'd also suggest that you add some more detail to your post.  Perhaps even an image as to what you are talking about.  It would go a long way in clarifying what you are talking about and in selling your idea to entice people to kudo it.
Message 3 of 8
(1,301 Views)
That's good feedback RavensFan. To clarify, currently, if you use rotate 1D array in a single cycle timed loop, you get an error like this:
I don't think there's any fundamental reason why that shouldn't be allowed. It was probably disallowed incase someone wired a control into the n terminal at the top.
Message 4 of 8
(1,294 Views)
It is probably because rotating an array is computationally expensive, and might not be guarenteed to execute in the given time.
Jon D
Certified LabVIEW Developer.
Message 5 of 8
(1,290 Views)
Mythilt, in an FPGA (which is what this idea is actually for) a rotate with a constant for the number of elements to rotate should be nothing more than a routing issue.  No computations needed.  Admittedly, it probably is because of the non-constant rotations that it is not allowed inside of a SCTL.
Message 6 of 8
(1,284 Views)
It should be equivalent to something like this which is a pure wiring operation and is allowedrotate with array.PNG
Message 7 of 8
(1,282 Views)
Interesting, I did not know that FPGAs handled arrays that much differently.  Have to do some reading on that.  Makes sense due to the limitations of their embedded nature.
Jon D
Message 8 of 8
(1,272 Views)
