Yaridia,
sounds your English is more problematic than mine - we can switch back if you think
To your Q:
If the string is always the same, than you can use the boolean text,
that -in my example- says now 'On' or 'Off', dependng on the boolean
value.
If you need to display a whole list of different, but well-defined
strings, I'd suggest to add an enum to the cluster. Those enums define
a list of predefined names or strings that are handled via a kind of
number or index. Think of it as a list of, say student, names. Number 0
is 'smith', number 1 is 'Miller' and so on. Using an enum makes it
easier to handle those strings, as there is no chance of a typo.
If an enum does not fit your needs, you may use a simple string instead.
Edit the cluster in such a way, that the boolean text is no longer
visibel and put the enum or text on top of all others. make its
background transparent as well.
BTW, having such a cluster with several elements, it is always a good
idea to make this cluster a type definition. Double-click the cluster
to edit it. In the new window, change the selection box that states
'control' to 'Type Def' or, as the optics of this cluster seems to be
relevant, to 'Strict Type Def'. Do all the optics, sizing, positioning,
coloring etc and save this. Now you can bundle the apropriate string
value into each cluster element for newly incoming data...
Greetings from Germany!
Uwe
