Air of the Square power of a generated signal.
I need to generate a current into a coil and then calculate the Impulse given by the force caused by the generation of the current into the coil, the current is generated as a Pulse.
-Current J(t) is generated as a Pulse.
-Force is a function of the current generated, F(t)=0,5.L.J(t)^2, ( L is unductence and J is generated pulse current).
-Impulse is just the air under the Force graphe but  how can I get the graphe of the Force?
An eXemple is attached.
Thank you for helping me .
(2,277 Views)
Dear Archer99,
I do not understand your question, partially also because your VI is complete as you described according to your equations. Almost: a square sign is missing. But that is all. Could you explain closer your problem?
Cheers,
(2,168 Views)
