Agilent n6700
Hi there,
How do I set values for multiple channels for an Agilent  n6700 at one instant? The channel port only accepts one number, should I put in three Agilent N6700 vi's in a frame? Or one Agilent N6700 vi with multiple channel references in the channel port.  Thank you.
(3,805 Views)
Accepted by topic author vvhh221
You can use three separate instances of the function wired one to the other with the VISA resource name or put the VI inside a for loop.
(3,801 Views)
A FOR loop is definately the easiest way to do this.  Make sure you are using shift registers for the VISA Resource and the error cluster.
(3,781 Views)
Thanks for your help.
(3,765 Views)
