08-06-2009 08:20 AM
I need to be able to read .csv results files from an Agilent 8753ES, into my LabVIEW programme.
However, I don't yet have access to the 8753ES.
Can anyone provide me with a sample .csv file from the 8753ES, so that I can make a start on producing the code?
Many thanks,
Dan
Solved! Go to Solution.
08-06-2009 08:58 AM
08-06-2009 09:24 AM
Essentially, we plan to build a number of RF test jigs to be used in production test. Each jig will be characterised on the network analyser at the time of building. The intention would be to generate a CSV file of, say, its S21 characteristics across a frequency range.
When a given jig is taken off the shelf for use in production test, the operator will have to select the corresponding CSV file, so that the LabVIEW programme can use this data to compensate for variations from one test jig to another.
The file format I had in mind was as per page 259 (4-43) of the manual at http://cp.literature.agilent.com/litweb/pdf/08753-90479.pdf.
I was just after an example of the file format (with whatever column headers, whitespace, etc.), so that I can read the file in and get LV to extract the relevant data.
08-06-2009 10:06 AM
You can also simply gather the S21 data directly from the network analyzer and then you can save it in whatever format you want. That's essentially what we do here to collect calibration data for the RF paths for the test setups.
Attached is an example of a .csv file. This is the S21 data for a sweep of a through-adapter.
