Do you mean the 81104A? If so, here's
the driver. If not, it may work anyway if it is the same class as
the 8110a. If that doesn't work, you can request a driver be made
here. If we get enough requests, we will create the driver. Next time you may want to try posting to the Instrument Control Forum instead of LabVIEW.
Robert Mortensen Software Engineer National Instruments
A driver for the 8116A is in the driver list. Perhaps that can be modified to do what you want. The 8116A is a Function/Pulse generator. I have used the LV 4 version but it appears there are newer ones on NI's web site.
