02-08-2007 04:08 AM
02-08-2007 08:06 AM
02-08-2007 08:12 AM
02-08-2007 08:44 AM
The pulses are from a power detect circuit and produce a pulse 520ms long with amplitude of about 2V. All the pulses are the same and are from seperate circuits that is why the pulses could arrive at the same time. The pulses are created from 4 different devices that burst every minute. I would somehow like to measure the pulse in the centre of the peak. Normally i would use a scope and set the cursors for gating and then measure the mean. Dont think the datalogger can do this and not sure exactly how long the datalogger samples each measurement for. I have to be carefull not to include rising and falling edges when measuring the pulse. Accuracy of 2 decimal places would suffice. The 16 channel multiplexer has a switching speed of 250channels per second.
Ideally i would like the datalogger to be waiting for each signal and trigger on the rising edge then somehow measure the peak of the pulse only avoiding edges. This result would then be read into my PC.
02-08-2007 10:02 AM
02-09-2007 08:53 AM
an alternative would be to replace the hardware entirely. National Instruments do have simultaneous sampling cards (so no MUX involved) to fit inside a PC or on USB which would give your timing results to a greater resolution than 4ms, but of course there's purchasing cost involved in that.
Here's a good starting point : http://sine.ni.com/nifn/cds/view/main/p/sn/n1:7689,n18:Y/lang/en/nid/1036/ap/daq
and here http://sine.ni.com/nips/cds/view/p/lang/en/nid/201880
The main difference between one of the simultaneous sampling solutions and your existing Agilent 34970A is of course the digits resolution. You have 6 1/2 digits voltage resolution (about 21/22 bits), versus the 16 bit products I've pointed at above.
Other alternatives are to go with a much higher sample rate and not simultaneous sampling which would lower the cost quite a bit.
Not pushing this as "the" solution, just something you could bear in mind for the future. If 16ms accuracy is all you need from the system, then as Lynn says, overlapping pulses aren't an issue. (16mS is the time sampled for all the channels to go through if smapling 4 channels so that's the samples / second / channel numbers.)
Sacha Emery
National Instruments (UK)
