02-08-2018 09:30 PM
Attached are 34401A Error and 34401A DMM screenshot.
34401A connected to laptop via RS232 to USB(COM4).
02-08-2018 10:28 PM
Do your serial port settings match? Do you have the right cable?
Is there a problem in your VI that we can't see because you didn't attach your code?
02-09-2018 12:18 AM
Attached is Device Manager Serial Port settings and vi Serial Port settings. Both have similar values. It still prompt error.
Attached is USB to RS232 DB9 Mini Gender Changer.
I am using Agilent 34401 Read Single Measurement.vi that is default from LabVIEW.
02-09-2018 12:42 AM
Hi Evans,
Well, the COM port in the device manager just shows its default settings.
That doesn't mean your device is using the very same settings!
So again: do you use the very same COM port settings as your DAQ device?
Your device is not responding according to the error message ("Timeout"). Does it even receive commands?
02-09-2018 12:59 AM
Since you mentioned "doesn't mean your device is using the very same settings!", can you kindly guide me in clear steps to change the 34401A port settings.
Can you kindly guide me the steps to check if it receive commands
02-09-2018 01:12 AM
Hi Evans,
There should be a separate chapter in your manual for that device. Just read it!
Most often such DMMs have a display showing the current settings.
When you send a command to change a setting you will see that change in the display too.
So does the display change when you send a command?
02-09-2018 03:10 AM
Definitely no display change between LabVIEW and 34401A.
Problem could possibly be mini gender changer.
Null modem should be use, not mini gender changer.
Source: https://forums.ni.com/t5/LabVIEW/RS232-to-USB-with-Agilent-34401A-and-E3631A/td-p/3546010
02-09-2018 07:59 AM
If you need to use a gender bender in order to get the cable to physically plug into the port on the DMM, that is a pretty strong indication that the DMM is not behaving as a DTE device but a DCE device. If you read the manual, it should tell you whether or not you need a null modem cable. (they would usually have female connectors on both ends since they are designed to connect two DCE devices, like PC's, where they would have male ports (pins), on the device.
