Agilent 33210a output disabled in remote use
I am trying to use this instrument driver (2018 version) with labview 2019 to make an agilent 33210a function generator to output a triangle wave. The problem is that every time I run the VI (which runs without errors) the function generator displays "output off" and no signal comes out. Some relevant information is that when I launch the vi labview returns the following warning message:warning_message.JPG
I think that this means labview can't find the necessary files for startup from the instrument library, but I don't know where those would be since they aren't in the instrument driver folder I downloaded.
(948 Views)
Those drivers were written to be in the <LabVIEW>\instr.lib\Agilent 33XXX Series folder.  You seem to be cross-linking your drivers as well.  So put the files for this driver where it belongs and try again.
GCentral
(939 Views)
Firstly, the Agilent 33xxx Series folder belongs in your LabVIEW xxxx/instr.lib folder.  It may just start working if you do that.
EDIT: Guess I was a bit tardy.  😉
Bill
CLD
(Mid-Level minion.)
(937 Views)
