Reply
After taking data from o-scope how to calculate the rise time of the waveform?
Highlighted
Hi everybody,
During autotest of HVPS I'm taking waveforms from Tektonix TDS420 scope and displaing on the Graph. After that I need do some calculation with that waveforms. I can do measurements as a frequency and amplitude. And I can measure the peak also. But I need to measure the rise time.
This is a waveform what I am trying to play with.
I'm working on the LabView 8.0
Thanks a lot
Boris
(1,551 Views)
You can use the "Transition Measurements.vi" and the output duration is the rise or fall time.
Take a look at it and see if it helps.
PS Your waveform didn't show up in your post.  If you have some data stick it in a VI and attach that so we can see what you have already tried and help you get to the final solution.
(1,546 Views)
