After correct measurement of 1 channel 1 sample analog data 1 per minute with the USB 6009 for 2 days, the device stops with the error -50405
Hi Hossein,
I already set the registry not to allow to turn off power of the USB hub. Thanks anyway.
Bart
Message 11 of 14
(444 Views)
Hi Bart,
Did you follow that too?
http://support.microsoft.com/kb/895962
Hossein
Message 12 of 14
(436 Views)
Hey bart.
It sounds like you know about the power management- and using a quality externally powered USB hub.  There is one other common cause- a USB device that is not 2.0 compliant being connected or a problem USB device connecting or disconnecting from the same hub.  Is anyone slipping another device in or out of the hub? is there anything else on the hub?
"Should be" isn't "Is" -Jay
Message 13 of 14
(422 Views)
Hai Hossein,
I will look into the registry settings,
thanks
Bart
Message 14 of 14
(411 Views)
