Affected callers: how to read the message in Load and Save Warning List?
How I can understand the "1" and "4" marked by yellow in the screenshoot attached?
(2,856 Views)
looks like a portion (probably a single VI) of vi.lib got copied into your project and is loading from your project folder instead of vi.lib.
"1" and "4" show you which VI's are using the subVI that it found in an unexpected location (e.g. not vi.lib).
In your project, expand "dependencies" and you'll find a vi listed with a yellow flag on it.  Easiest way to fix it in this case is right click and say "replace with" and navigate to the LV palette with the function.
(2,835 Views)
I'm not using a project.
How to get known what "1" and "4" refer to?
(2,785 Views)
