Adjusting variance in samples
I have a test program that I am using to test hydraulic pressure. I am recieving a 0-10mA signal from a transducer, recording the signla over a period of time, with a tolerance for pressure limit. The current problem I am having is that the pressure displayed will vary between 50-300psi on the "Valve Pressure" field.
I am sort of at my witts end and need some help. I am looking for a way to maybe average the incoming samples more, but keep the same recorded number of points - my thought is that if I average the samples more it will make the samples decrease in variance.
(2,457 Views)
One way you could do this is by using the Mean PtByPt.vi.
Applications Engineer
(2,424 Views)
