You are going to have to explain what the problem is. In the code you attached, there is no read from spreadsheet. If you are trying to read from some specific file, it would help if you attached that file. Also, Read From Spreadsheet does not mean Read From Excel. Spreadsheet refers to tab or comma separated text file. Reading from native Excel files is completely different and requires the use of ActiveX.
