Hello.
I'm a student doing my thesis work in sweden and I'm quite new to LV.
I read the manual for porting emb.LV Runtime but don't have an idea where I have to start with.
my platform is an microcomputer (NetDCU8) with an ARM 9 prozessor, touchscreen, Network, serial ports, SD-Card and ADC's running embedded Linux (Emlix).
The graphic part I allready programmed in C/C++ and it could be running as a thread.
This is what I need to programm within LV:
- starting the graphicfunction as a thread
- reading values from ADC's and store them into global Arrays every 60 seconds
- doing some calculations with those values
- storing values into logfiles onto Networkfolder and SD-Card (both mounted when the target start up Linux)
I'm able to do all this stuff in C/C++. But as a part of my thesis work, I have to make emb. LV useable for programming for my target.
The BSP is only for Linux-Computers.
I'm not very familar with operating systems and have zero experience in porting anything.
But if there are some good hints, where I have to look at and what I maybee can use, that's already done, then I think I have a chance to manage it.
...I have only 1 month left for my work....
Best regards from Göteborg,
Tobias
