03-01-2012 01:48 PM
I need to add this registry entry with the Labview installer
For a default FTDI device ID (VID 0x0403, PID 0x6001), add the following registry REG_BINARY value set to 01
at
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\UsbFlags\IgnoreHWSerNum04036001
the installer has a place to do it but does not support binary only string & Dword
using LabVIEW 2011 on XP & Windows 7
I know the risks of playing with the registry..
03-01-2012
02:09 PM
- last edited on
05-21-2024
09:45 AM
by
Content Cleaner
Hi RRRRSSSS,
If the installer does not give you what you require, my suggestion would be to create a VI using the Windows Registry Access VIs. You could then create an executable, and add it to your installer to run after installation.
This is just a suggestion, the registry is a dangerous place - take care ![]()
03-02-2012 10:01 AM
I built the write registy.vi and created an exe for it.
I already have an exe I need to run so I created a .bat file to run both of them which will be called after installation.
I'm having an issue with the write Registry.exe showing up in the "source file Settings " is shows up as a folder.
When I do a preview it the write registry.exe does not show up in the preview list, the .ini and the .alias show up and the other .exe shows up.
What am I doing wrong??
03-05-2012 05:53 PM
03-06-2012 06:25 AM
The write registry.exe is not a folder its and exe, Labview is showing it as a folder..
I have it figured ..
