09-03-2019 12:26 PM
Hello all,
I have a project that I am trying to deploy using an installer. I am not having issues with the build process or necessarily the deployment, but have encountered a new and frustrating issue: I had built and deployed an installer with a file being deployed to a particular directory in the installation process. Now, my customer wants me to not automatically deploy that file but leave the existing file in place during and installation. However, when I remove this file from the installation package, it removes the existing file from the customer's directory during the installation process. I am not certain I have encountered this and it only seems to delete files that were previously deployed as part of the installation process. Does anyone have any thoughts on how to work around this?
Solved! Go to Solution.
09-03-2019 01:04 PM
Build an executable to see if the file exists and copy it to a temporary location and run it before installation. (from the Advanced page of the installer build spec.)
Build another executable to move it back from the temporary directory to the desired installation path if the file exists in the temporary location and run it at the end of installation. (from the installer build spec advanced tab)
09-03-2019 01:34 PM - edited 09-03-2019 01:35 PM
The advanced page provides a way to run an exe after installation and before uninstallation. After installation is too late.
09-03-2019 01:44 PM
Not when the file was copied to the temporary folder before the uninstall process (which occurs when there was a previous version of the product installed)
09-03-2019 02:01 PM
OK - so what you are saying is that when you install over an existing installation, the uninstallation script is run first?
09-03-2019 02:16 PM
Yes, if the existing product was installed from an installer, rather than just copied to disk, installing updates should uninstall the installed product and update the product.
Of course- you used an installer right?
09-03-2019 02:38 PM
See the OP above.
09-03-2019 11:06 PM
Ugh...going to trade my accept for a kudo here as this works - if the uninstallation exe exists before installation. It appears that we have a chicken and egg problem here and I am still stuck with not being able to leave a file that was originally placed with the installer in place.
09-03-2019 11:14 PM
OK...figured out a solution to this conundrum and that is (drum roll, please) - simply copy the existing installation project and then remove the files from the installation that I do not want to update. Ta-da!
09-04-2019 05:09 AM - edited 09-04-2019 05:24 AM
Its a workaround...it requires manual selection of which installer to use depending on whether you are installing new or updating existing.
Personally I think that I would use the windows apps and settings to uninstall the product ( after copying the file to persist to a temp folder) on currently installations then just run the improved installer. For all cases. No future troubles because all installations have been installed with proper uninstaller instructions.
Your preuninstall exe could even offer a user option to replace existing file with factory default...a sometimes useful repair feature.
