Adding an indicator to a buffered XY Graph that displays data in "real time"
I have a buffered (5000 data points) XY Graph that displays 2 plots as a function of distance.  I would like to add an indicator (cursor?) to the graph which moves along the plots to indicate the current position.
I tried adding a cursor and updating its position with a property node as the position changed.  However, the position changes rapidly and the data needs to be displayed in "real time".  When I update the cursor dynamically with a property node, it slows down the display until it is unusable, for all intent and purpose.
Ideas?
(2,312 Views)
Decimate your data and and keep your update cursor refresh rate to something around 100ms or so.
(2,308 Views)
