Adding a pulse (train? timer?) to digital output pulse VI.
You do not need to connect the boolean to the beginning of the For loop, if you are passing an array into the for loop and have the array auto-indexing (the [ ] on the entering connection) then the For loop will run the minimum of the sizes of the arrays (if you have an array 4 long and an array 2 long and they are both auto-indexing the For loop will only run twice, reading in the first and second values for both array)
For starting the whole thing with a boolean press in the event structure where you had a single DAQ assistant replace it with the loop.
Message 21 of 21
(503 Views)
