Adding DAQmx measurements to multicolumn listbox or tree
Hi all,
i have 128 thermocouples to taking measurements instantly, i would like to ask you to do that;
i want to buid a multicolumn listbox or tree to insert all of to measurements, channel colour, and the thermocouple which can see on waveform graph by thicking and the vertical scroolbar at the same time.
first screen is builded by myself and the second screen has been taken from the signal express. can you please advise or show me an example to build this kind of mixed listbox or tree
(1,039 Views)
The second image looks like a tree with horizontal and vertical lines enabled and in the child the data is added
CLD Using LabVIEW since 2013
(1,036 Views)
Hi Oserbetci,
@Oserbetci wrote:
can you please advise or sen me an example to build this kind of mixed listbox
You can use a multicolumn listbox to create such an UI…
  • You can set (background) colors for single cells.
  • You can show different symbols in front of the first column.
  • You can change all cell items as needed…
(1,029 Views)
thank you for your answer,
 do you have any example to see enable the horizontal and vertical lines and the adding data's to tree?
(1,021 Views)
You can install the Qcontrol toolkit from vipm and see its example for tree and other examples to add item to tree and lines can be enabled with right click and visible them
(998 Views)
