Add content to typedef constant
I created a strict typedef constant containt references to controls and indicators which made a .ctl file. I now wish to add more control references to the typedef but can't figure out how... I tried to add the new control references directly to the typedef constant. This failed. I also tryed opening up the typedef which opened the .ctl file. This also was a non-starter as you can only view the front panel meaning I can't add references to the typedef constant..?
Any ideas?
Strokes
(3,528 Views)
Accepted by topic author Strokes
I'm not too sure what you're trying to do, If you want to edit your typedef (add-modify remove controls to it) then of course you have to open it, do you modifications and save it ; then modifications will be propagated throughout your soft wherever you typedef is used.
The fact that you want to add a control reference control to your typedef doesn't change anything.
Typedefs don't have a block diagram, and you to add a control ref control to your typedef, you can do it from the front panel, just go to your the appropriate palette (Refnum)
Hope this helps
Epictetus
Antoine Chalons
(3,522 Views)
