translated by google:
Hi, I'm new to Labview. Let's see if I can help, any comment is welcome. I have a question: If I have two arrays with n number of rows and two separate columns that are initialized with the same random number data in the first cycle of the memory matrix row lists the best value and keeps it in the matrix, the next cycle if better data is sensed replaced. I do not quite understand how to do that, which led Annex uu them any support would be great. Thank you very much.
Your Vi is just a random collection of code fragments that have little to do with the question.
In general, you would simply keep the 2D array in a shift register initialized with a 2D array of the desired size and replace elements as needed. I don't think you need any of the local variables but you probably need an outer while loop.
