09-08-2020 03:22 PM
I'm trying to get started with Actor Framework by using the default template. The NI developer demonstration shows that the event log should pop up after splash screen. However, when I create a template and go straight to running the splash screen, the application stops after splash screen is complete. I noticed the Actor Core.vi has a broken run error(the one associated with the event log UI).
Here is the error message for the Actor Core:
This VI doesn't match other VIs in the method, the scope is different. All VIs that implement a method of a LabVIEW class must match scope (public, private, protected). To correct this, compare the scope of both this VI and the VI of an ancestor class that implements this method.
Is anyone familiar with this issue? How do I go about troubleshooting this?
09-08-2020 05:51 PM
I confirmed that the template works fine on my other PC. I'll likely just upgrade to LabVIEW 2020, that should fix the template
