This issue has been reported and fixed in LabVIEW 6.1. If you can, please upgrade. If you cannot, then make sure you close all references to this ActiveX control (at all levels) using the Automation Close primitive in LabVIEW. This will also solve this issue.
One last suggestion, if you are doing work with this control in a loop, then place a small wait inside of the loop to give the control a chance to update properly.
Randy Hoskin
http://www.ni.com.ask
