12-06-2006 11:47 AM
12-07-2006 03:35 AM - edited 12-07-2006 03:35 AM
Right click on the object container on your front panel the select Property Browser then set AutoFit=True.
Edit: Its also available as an property of ISpreadsheet.
David
Message Edited by David Crawford on 12-07-2006 09:37 AM
12-07-2006 10:24 AM
AutoFit doesn't work after manually resizing the container. Do you know how to enable it again after resizing the container?
Albert
12-07-2006 10:32 AM
Your right it doesn't when you toggle the property in design mode. Just use the property node to Autofit when you run your code.
David
12-07-2006 10:49 AM
That also doesn't work.
Albert
12-08-2006 11:54 AM
12-08-2006 12:04 PM
I have my program getting the monitor settings but those values are dots on the screen and they aren't related to "points" or inches. Or are they and I'm missing something?
Albert
12-11-2006 01:36 PM
12-11-2006 05:24 PM
12-12-2006 11:39 AM - edited 12-12-2006 11:39 AM
Message Edited by Steven C on 12-12-2006 11:41 AM
