Acquiring signals at different rates
@crossrulz wrote:
@guhal wrote:
Further, what did you mean when you said to resample at the lower rate?
This is a signal processing trick to take a lot of data and condense it.  There are pros and cons to doing this.  Less data = less power.  Less data = lower bandwidth.  But simple ways to "resample" your data is to perform an average on every X samples to reduce your rate by a factor of X.  More involved resampling (what I was taught in school) is to decimate your data and then apply a filter.  There are VIs specifically for resampling your data in the Signal Processing palette.
Thank you Tim!
You said what I would have said but better (smiley-wink).
guhal,
Unless you can specify WHY a lower sample rate is required, take the more direct approach and supply more than what is expected.
Ben
Message 11 of 12
(391 Views)
In other words: It is usually better to have too much information than not enough.
GCentral
Message 12 of 12
(384 Views)
