Acquiring AI in PCI 6143
Hi
I am trying to acquire constant Analog signal of 65mV from a sensor to computer through PCI-6143 and for that used a DAQmx.
However the signal is constant but during acquisition it seems its oscillate, Here picture attached. How i can acquire constant signal without averaging.
I have tried, sample on demand,continuous sample and N samples mode but in every condition signal is varying.
Need suggestion to resolve error, without averaging my signal.
thanks in advanced
(2,688 Views)
Accepted by topic author hussey
It looks like you may be picking up some 50Hz mains ..?
An article here about making analog measurements may help.
http://www.ni.com/tutorial/7113/en/#toc2
(2,682 Views)
In multimeter its shows me constant values.
(2,680 Views)
What type of sensor are you using ?
(2,673 Views)
Thanks budy....
it was 50 Hz noise. It was coming from external power supply of my sensors and due to that original signal was continuously fluctuating.
(2,640 Views)
