Accessing to Smart Card Readers PC/SC with Labview
Accessing to Smart Card Readers using Labview
This program is an example that how access to Smart Card Readers (PC/SC) to get some information about a SIM Card, this program is not debuged yet and have some issues.
The point is wear the  winscard.dll where  all the function to access to this PC/SC readers are defined, I don´t have enought skills as programmer, but I think that it could be help somebody to develope
applications with Labview and SIM cards (GSM, USIM, etc..)
Regards
Message 1 of 28
(11,061 Views)
Enrique,
Great job on the VI.  To make it easier to read and maintainable I might suggest cleaning up the code a little (aligning things, straighten wires, etc.).  You would be amazed how much easier to use code becomes when just a little effort is put into the Block Diagram.  All and all, good work!
Andy F.
Message 2 of 28
(11,015 Views)
I have been looking for a similar solution for some time. I've been using a .NET component (Included. remove the .txt extension) to send and receive APDUs to GSM SIMs for the past eight months but wanted a direct LabVIEW solution to interfacing with winscard.dll. Perhaps you could communicate with me directly to share development.  The code to manipulate the SIM expands several VIs and is not in a form I can share. I can be reached at riveratony@ieee.org.
Message 3 of 28
(10,983 Views)
@Andy F. wrote:
Enrique,
Andy F.
Hi Andy
I have a lot of work and finally I had time to clean the code.
Regards.
Message 4 of 28
(10,946 Views)
Hi Enrique ,
The  "GETTING_ATR_FROM_SIM_CARD_GSM_cleaned.vi"  is not able  to open in Labview 7.1 . It says " Labview 7.1 has encountered some problem and need to close ". Can you please help me in this . If you could post the vi again it will be more helpful.
Thanks & Regards,
Venkat
Message 5 of 28
(10,904 Views)
Here you are my friend!
This code was made in Labview Express 7.0.
Best regards.
Enrique
Message 6 of 28
(10,871 Views)
Thanks a lot  Enrique
But Still I get the same Error Message.
If you could rename the VI and then send ,it will be helpfull to me.
Thanks & Regards,
Venkat
Message 7 of 28
(10,863 Views)
I thinke that I have the same problem and need your help. I want to read the SIM s tel number. In my application I have  around 22 DLL functions and I dont really know if I should use all of them or which one of them. I 'am connecting my GS64 modem whith the PC via RS232.
Best regards
Message 8 of 28
(10,589 Views)
Hi dlawer,
I google'd your question and it looks like there is not an AT command to retrieve the telephone number:
http://www.wavecom.fr/modules/movie/scenes/forums/viewtopic.php?p=3938&sid=7d1385e36de04b9952e9839ac...
Saludos,
Erin B.
NI Mexico
Message 9 of 28
(10,569 Views)
Hello!
Let me first understand your question,  Do you want to know wich of 22 DLL´s, that you have, can you use to sent an AT command to retrive the MSISDN on SIM Card?
If you answer is yes, you should be identify all the functions in your dll and found wich of them ara used to sent AT commands like SMS send, SMS retrive, etc.., the same structure of this commands you can use to send another AT Command.
The number should be record on the SIM Card.
AT+CNUM Subscriber Number
Description:
This command returns the MSISDNs related to the subscriber (this information can be
stored in the SIM or in the ME). If subscriber has different MSISDN for different services,
each MSISDN is returned in a separate line.
Test if the command
is supported
AT+CNUM=?
Best Regards.
Enrique Ramos
Telcel Mexico
Message 10 of 28
(10,556 Views)
