01-15-2011 04:46 PM
I am reading large data from a file and storing it in a cluster, I want to use this cluster in different sub vis to access and process the data. I am a beginner to labview programming and your help is appreciated.
Thanks !
01-15-2011 07:27 PM
That's a pretty basic question. Before trying to do anything serious in LabVIEW take some time to go through the tutorials. Start here.
01-16-2011 01:04 PM - edited 01-16-2011 01:04 PM
hi
you can use, for instance, a notifier. See the master slave template.
N
01-17-2011 04:38 AM
you can create SubVIs giving the cluster values inside it.
I made some screenshots to explain the steps:
1) Right-clicking on the VI-symbol on the FrontPanel and select show connector
2) Click the connector and then the FrontPanel object to make the connection
3) Repeat this for every value you want to give to the main-VI out of the subVI
4) Right-clicking on the connectors field and select show icon
5) save the subVI
The subVI can be included into the main-VI per drag an drop out of the windows explorer.
I hope this helps.
Best regards
Suse
01-17-2011 04:39 AM
rest of files...
01-30-2011 11:24 PM
Thank you very much for your detailed explanation. Since I was a basic user and took some time to go through many materials to understand the concept. Once again thank you for your support.
