12-22-2005 12:52 AM
12-22-2005 03:03 PM
Hi J.A.C,
I cannot think of a Palm PDA with a built-in USB port but then, I may be wrong. Are you may be talking about a custom USB connector that connects to your device via serial cable? If that is the case then you are looking at Serial and not USB communication. Please clarify.
Ankita
12-23-2005 06:39 AM
Hi Ankita,
Thanks for your interest.
Previously PDA used to come with serial ports. But, now-a-days most PDA's come with USB Port. There is no serial port in them.
My PDA has Palm OS. LabVIEW PDA module provides serial VIs to communicate with serial port. But since now, there are no serial ports, i cannot interface my USB device to the PDA. I would like access USB port on PDA running Palm OS. As far as i know, there is no direct USB support in the LabVIEW PDA.
So my question is how can i access USB port (indirectly/using external code/anyway) on PDA running palm OS using LabVIEW PDA module.
Hope i am understood.
Thanks.
J.A.C
12-23-2005 10:55 AM
Hi J.A.C,
I have a Palm m130 pocket PC. I was hoping to experiment LV with it, but could not interface to it either...
it basically collects dust since all it is useful for is a phone list (which is already in my cell phone).
I hope someone can provide some info, too... and revive the old PC (it does have the color screen) 😉
12-25-2005 09:54 PM
Hi Joe,
Sure, you could use your Palm m130. Though now-a-days with advent of modern day cell phones, PDA's are getting obsolete. However no one can deny their use in data collection and industrial application.
You need to have LabVIEW PDA module (similar to your RT module) installed on your PC to access your PDA from LabVIEW.
I am also a beginner with LabVIEW PDA and am facing lot of difficulties doing application development in LabVIEW PDA. There are few contraints on usage of Front panel objects and no direct support for USB. This make it difficult to use it for large application development on PDA. However i hope to work my way out.
Good Luck !
J.A.C
05-28-2008 11:27 AM
hi , i am using palm m 130 . Can u Please tell it is compatable for serial communication using Labview Pda?
05-29-2008 05:22 PM
06-02-2008 01:20 AM
06-03-2008 08:58 AM
