Accessing DMA on dspPIC33fj256
I am looking to transfer data from a MCU to a PC via Direct Memory Access (DMA) module on a dsPIC33F MCU. The UART reciever needs to issue a request. I have attached the code for the UART and getting data from the ADC on MCU but I need a way for labview to access the DMA on request via uart. Could somone show me where i need to add that in my code.
(3,308 Views)
Which part are you having difficulty with? Have you read the Microchip manual for doing DMA transfers over the UART? I'm assuming it specifies some sort of protocol for requesting a DMA transfer and the data that it returns which you can then process in LabVIEW using string functions and/or converting to an array of bytes.
(blog)
(3,273 Views)
well i have it in my code if you take a look, the string conversion for the viewing the data but im assuming labview needs to send a request to get access to DMA.via uart back
(3,269 Views)
(3,267 Views)
