07-21-2009 12:20 PM
Ive recently tried to get ahold of the anritsu_37xxx_series drivers, I was using them several weeks ago successfully but have now accidently changed some small detail in the block diagram and which is solvable with a fresh set of the drivers. These drivers were recently updated as of July 7th and now require Labview 8.2, for compatibility reasons I do not wish to upgrade at this time, is it instead possible to download older versions of drivers?
Jonathan
Solved! Go to Solution.
07-21-2009 02:20 PM
If NI can no longer provide them, then you can indicate which version you need them in, and someone can try to back-save them for you.
Will require you to give Kudos, though.
07-22-2009 04:11 AM
By back-save them do you mean someone else uploads them to the NI site? How do I go about doing that?
And can you give a quick explaination of the kudos system here then please?
Thanks!
Jonathan
07-22-2009 08:43 AM
LabVIEW can save a VI or a VI hierarchy so that it can be opened by a previous version of LabVIEW, but up to a certain point. For example, LabVIEW 8.2 can back-save to LabVIEW 8.0. 8.0 can back-save to 7.1, 7.1 can back-save to 7.0...
You can try to contact NI directly to see if they still have the older versions of the drivers. If not, then indicate which version you need them in, and which drivers you downloaded (i.e., the link to the page).
Kudos are just "thanks". You provide them using the star in the orange-like box on the right-hand side of messages.
07-23-2009 01:15 PM
07-23-2009 02:18 PM
