06-15-2009 03:16 AM
Hello everyone. I have a question about accessing a .dll file in LabVIEW. I am using a spectrometer by Newport Oriel and this spectrometer comes with its own software. The software is installed on a PC and can only run when the spectrometer is connected to the PC via USB. The problem is that I am using this spectrometer remotely and therfore can not connect it directly to the PC, and thus the software will not open. I have the spectrometer connected to an NI Wireless Module (WLS-9163), and the PC connected to this via wi-fi. The software that comes with the spectrometer was built using LabVIEW, but I only have access to the .dll file and not the code itself. I want to access this .dll so that I can somehow incorporate it into a VI that I will create and ultimately run the spectrometer software. Any suggestions on how I can go about doing this?
Thanks...
06-15-2009 03:54 AM
Speaking on general basis you can call the DLL from Labview. But you will need to know the function prototype for each function in the DLL that you are going to call. If you have this you can create our own controller program. Maybe I am wrong but your setup seem to me somewhat strange. The WLS-9163 is made for wireless daq units so doing instrument control is hard to do. Perhaps you will be better of with a wireless USB port/hub. Google "wireless USB port" or "wireless USB hub" these devices do not cost much
06-15-2009 03:49 PM
Hey vmuro,
You can incorporate your .dll within your own LabVIEW code through a call library function node. However, as Coq rouge mentioned, you are going to need to know about the function prototypes to effectively use this method. Check out this Tutorial and NI Community for a little more information on the call library function node and incorporating .dll's in your LabVIEW code.
07-02-2009 07:42 PM
07-06-2009 11:24 AM
Hey vmuro,
Are you having trouble installing the INF file created through the Driver Development Wizard (DDW) or are you having trouble installing NI VISA itself? Do you have any more information on what the error is? A screenshot, a more detailed description of the error, and an idea of when the error actually occurred would be helpful.
07-10-2009 01:52 PM
07-13-2009 10:05 AM
Hey vmuro,
It is strange that you are having such problems as your computer turning off when trying to install an .inf file. My first question, however, is did this device come with some software? Can you communicate with your device using this software? Can you communicate with your device via this wireless USB connected with the software that came with the actual device? Once you plug in your wireless USB, can you see it in Device Manager?
The first thing I would try is insure that the wireless USB device is working properly with any software that came with it. Then I would worry about incorporating it in LabVIEW.
07-13-2009 12:55 PM
07-14-2009 04:30 AM - edited 07-14-2009 04:34 AM
vmuro wrote:
Thanks for the help. Yes, it works fine if I connect it directly to the PC or into the wireless hub. The computer recognizes it and the software is useable which ever way I connect it. It would be nice to incorporate the software that came with the device into a VI, but unfortuneately I do not know the function prototype, so attempting to use it with the use of NI-VISA was my alternative. Any help is appreciated. Thank you.
You will not have much luck. In order to control an USB device through NI-VISA you have to know the USB protocol very intimately to actually write the correct stuff to the correct USB control pipes and understand what the instrument returns. This is basically impossible without a thorough protocol description and such a description is notoriosly hard to get at.
The alternative is to use an USB protocol analyzer and log the data transfer that occures when using the native software. This is however a very tedious way of reverse engeineering and doomed to fail without some previous and serious understanding of USB operation.
Look for a post from Intaris here in this forum where he documents the steps and complications about developing an USB driver based on NI-VISA! Only if you have digged everything in there you can start to hope to be successful in trying to get your device to work over NI-VISA.
A more promising way would be to access the DLL through the Call Library Node IF AND ONLY IF you can get at the DLL interface documentation.
Rolf Kalbermatter
07-14-2009 02:09 PM
"A more promising way would be to access the DLL through the Call Library Node IF AND ONLY IF you can get at the DLL interface documentation"
This was my first attempt. The native software was created using LabVIEW, but unfortunately the manufacturer/developer does not want to provide this code. Then, I though since it was created in LV, maybe I could reverse engineer it or recreate it. It turns out that it is more complex than I imagined. Thanks for all the help...
