Access denied location services issue while running netsh wlan show net in labview
I am trying to detect a wifi by running in labview netsh wlan show net, but is giving this location service access denied error and on searching i found out this is an error associated with the latest windows. Is there a work around. Or is there any other way. I just need to detect a wifi signal , then connect to it and confirm the connection. Right now it is done using SSID. Is there a way to solve this problem or any other way to do this
(157 Views)
Windows blocks the action unless you enable location services. The logic is to prevent nefarious app makers doing background wifi scans to determine the user/victims location based on nearby SSIDs.
To make matters worse, under windows 11, the system doesn't do a complete wifi scan when you disable/enable the wlan programmatically.
This regularly causes a present SSID to be absent from the cashed list that "netsh wlan show..." delivers.
To make it work reliably you will also need to invoke a WlanScan function. https://learn.microsoft.com/en-us/windows/win32/api/wlanapi/nf-wlanapi-wlanscan
After this, the "netsh wlan show..." will return valid information.
A few hoops to jump through, but hope this helps.
0xDEAD.
(105 Views)
the location services is already turned on in my system and yet i get this error, i heard microsoft made it like that in windows 11
(98 Views)
