02-24-2014 09:09 AM
the solution to my problem must be so easy, that I can't find it.
Please see my small example vi.
I've got a waveform and I want to plot the data against the absolute time. In the graph properties I set the display format to "absolute time", but it didn't work.
transfererror
Solved! Go to Solution.
02-24-2014 09:44 AM
I am not sure why this is happening, but your scale ignores the timestamp, but that option is grayed out...
I am not sure why it happened, as it happens for newly created graph elements as well. Modifying the t0 and delta t, i managed to create a graph which does not gray out that option, but with the default settings, there doesn't seem a way to get this to work....
Norbert
02-24-2014 10:16 AM
Thanks for your reply, Norbert
With your help I found the solution.
See attached screenshot.
Nevertheless it seems to be a bug that the option is grayed out in the properties dialog. At least it is missleading.
Best regards
transfererror
02-25-2014 06:58 AM
transfererror
If Nobert's reply, helped you finding the solution, then you should mark his reply as solution.
You can un-mark your post as solution and mark the appropriate post as solution.
